94 caprice wont start help
a36mob
05-07-2008, 11:54 PM
ok i got a caprice 94 l99 it was driving perfect. i was on my way home then it started to put put then the engine cut. gave it like 3 mins it started drove 1 block started to put then the engine cut. now doesnt start at all just cranks the gas gauge says it has 1/4 tank of gas info anyone.
silicon212
05-08-2008, 12:56 AM
Did the MIL come on (service engine soon) before it died?
Check your fuel pump fuse. Use a voltmeter and check for the presence of 12.6 volts on the fuel pump power line - you will only see this for two seconds upon putting the key in the ON position - you may need help with this because you will likely need to do this a few times, and be prepared to view that reading quickly.
Check all grounds in the fuel pump wiring harness.
Check the fuel pump relay.
a36mob
05-08-2008, 07:59 AM
yeah it was the fuse it blew i replaced fuse good as new. it blew cuz my dad has the constent power comming out of there for the fans from a relay so that the fans could run all the time. my dad is going to run them off a switch due to there is too much load comming out.
j cAT
05-09-2008, 06:59 PM
these fans are not designed to constantly run....your fan/[s] may now need replacing....if the fuse blows again check for higher current flow to fan motor[s]...
perhaps your ECT needs replacing if fans will not come on at the proper engine temp...... good luck
showshocka
12-14-2011, 01:32 PM
what fuse was that? i'm having the same problem
silicon212
12-14-2011, 09:20 PM
#1. Necropost of almost 4 years!
#2, see my post above (#2).
