SMS CF Decals question
AceCobra1
05-07-2008, 10:56 AM
http://emotiondesigns.uk.ro/cfdecal.jpg
Hiya, just wonderig if you guys can tell me... I am not quite sure what the difference between the solid lines and the broken lines are for. I mean at the bottom of this undertray, I know i'm supposed to have CF decals but the solid line in the middle of Part C1 confuses me... do I need to cut on the solid lines so that it can confirm to the shape or what? How about the broken lines ? I take it at the rear C1 section, there are several bits I need to cut out on the CF decal there ?
MPWR
05-07-2008, 11:13 AM
The dotted lines on C1 are to match up the front and rear sections of C1- it would be very long on the decal sheet otherwise. Don't cut right on the dotted lines here- give yourself a cm or so on each to overlap.
As for the solid lines, use the kit part to determine what should and shouldn't be cut. There are some areas towards the rear of C1 that will have to be cut out, but the kit part will definitely be the best guide of which cuts need to be made.
AceCobra1
05-07-2008, 02:08 PM
Thanks for the info dude:smokin:
