1995 passport wont crank
odie241
05-05-2008, 01:06 PM
i have a question,i have a 1995 honda passport that i installed a clutch in,i have it all back together,bleed the clutch out,everything is great except for one problem,i must have the wires going to the transmission on wrong,because now it wont crank over,i have power down at the plugs where they connect,power at the starter,which worked when it came in,its a 3.2liter v6 with a 5 speed tranmission,there is four sesors in the trans,with 3 sets of wires coming out of the harness.there is a red and white wires,two greens,and 2 tans,now the way they connect,the red and white must go together,and the greens and tans connect,1 green with 1 tan,male female,i tried finding a wire diagram at the dealer,they said its too old for there computers,autozone,no luck,google,no luck,abput ready to just junk this thing,im lost and dont know what to do,,,,,any help as soon as possible would be great,as im spending a killer on rental car fee's.thanks,steve:confused:
Ramblin Fever
05-06-2008, 09:36 AM
How old is your starter or alternator? Do you have cab lights, dash lights, etc?
odie241
05-06-2008, 11:28 AM
hello,i have a new battery,alt. is fairly new,and the starter is good,i know this because i ran a jumper from the battery to the starter as it said to do in the haynes manual,it started right up when i did that.im wondering if i have the wires on the trans hooked up wrong,and isnt there a way to jump the neutral safety switch,im thinking thats where my problem is,this all stated when the clutch locked up,removed the trans,new clutch,pressure plate and throw out bearing installed,cant find a wiring diagram anywhere for this thing
Ramblin Fever
05-06-2008, 04:15 PM
sorry, i have the automatic....post this question on planetisuzu.com for JLEMOND - he is an Isuzu guru mechanic/specialist with fantastic years of assistance.
odie241
05-08-2008, 10:42 AM
ok sounds good,thanks for all your help(i put this in and it says website not found,tried searching google,with no luck planetisuzu.com)
FL 3.2L
05-08-2008, 08:59 PM
planetisuzoo.com, I think...
Ramblin Fever
05-09-2008, 12:55 AM
yep, sorry me bad....planetisuzoo.com
