Mini Me Tuning
sqmark
03-04-2003, 02:49 PM
I've just finished a D15B7/D16Z6 mini-me but now it's done I want to know if it's possible to fit a Skunk2 intake mainfold, ie: will the bracket fit? I say because on a friends B16 he fitted a B18 intake and the bracket didn't fit so he just cut it of and bolted it on.
sqmark
shepworldwide
03-04-2003, 05:43 PM
if it does'nt fit return it.
next
relientokay
03-04-2003, 06:24 PM
How hard was the mini-me project? I was considering doing it. How much did it cost? What kind of performance did you get? Just any info about the mini me would be great, thanks
ben
sqmark
03-04-2003, 06:33 PM
It was fairly easy. Basic service knowlege needed to change the distributor and timing belt, the ECU wiring is just 3 extra wires. Done in 1 day, came in at 132bhp at the flywheel. It cost a total of just under £700 so in the states I'd say under $1000 because you have a mass market so parts would be cheaper.
sqmark
03-04-2003, 06:36 PM
Basicly its a D16Z6 head, ECU, Intake mainfold with injectors and fuel rail and Distributor. You can either use a D16Z6 or Y8 headgasket depends, Y8 is almost half the size of Z6 so higher compression and VX timing belt.
B16EJ1
03-04-2003, 06:43 PM
There's another post on here saying that Skunk2 made an intake mani for the Z6. Just buy that one. Here it is.
http://www.automotiveforums.com/vbulletin/t89919.html
