control arm ring
OOge
05-01-2008, 06:15 AM
At the front of my chevy's control arm is a rubber thing with a metal ring. At on side the rubber and ring seems to be at the top of the arm. The other side has it in its normal place. In the control arm. Do I need to buy a new control arm, or just a bushing or something...
merc81
05-01-2008, 08:28 AM
I don't have the book in front of me, but if you mean the bar that runs from one wheel to the other wheel, it connects via a set of rubber washers, about 3" in total height. The bushing has steel washers and rubber spacers and allow the arm quite a bit of travel. I think you would need both wheels off the ground to see if both sides are at the same height. Its unlikely the bar is bent.
OOge
05-01-2008, 10:30 AM
I mean the control arm at the right. It has a pressed rubber bushing in it at the front (radiator side). The circle with the rubber in it seems to be on top of the arm.
merc81
05-01-2008, 12:51 PM
I'll look at the van and the book this evening and get back to you. Can't recall what you're describing. :popcorn:
dave_1976
05-01-2008, 11:41 PM
You can get just the bushing from the dealer. No need to replace the whole control arm. Make sure you have the last 8 digits of the vin when you go to the parts counter.
OOge
05-02-2008, 04:04 AM
Are you sure, it seems to be a pressed bushing. I mean the front bushings
kornjulio
05-02-2008, 05:39 AM
Yes, it is pressed. Call your local Chevy dealer to confirm parts and availability if you want an ACDelco part. Looks like Moog and Spicer also offer a replacement bushing according to rockauto.com
merc81
05-02-2008, 07:26 AM
Had a look at the van and the manual. Sounds like it wants a new bushing.
Here are some images that detail the bushing. If the scans don't show up nicely and need edited out from this post, you can view them at
http://cemrweb.cemr.wvu.edu/~mathews/boat/scans/
http://cemrweb.cemr.wvu.edu/~mathews/boat/scans/bushing2.jpg
http://cemrweb.cemr.wvu.edu/~mathews/boat/scans/bushing1.jpg
http://cemrweb.cemr.wvu.edu/~mathews/boat/scans/bushing23.jpg
http://cemrweb.cemr.wvu.edu/~mathews/boat/scans/bushing4.jpg
http://cemrweb.cemr.wvu.edu/~mathews/boat/scans/bushing5.jpg
OOge
05-02-2008, 04:08 PM
thanks guys. I'll go change the bushing
By the way which manual are you using. This saves me posting.. :)
merc81
05-03-2008, 11:20 AM
I have the Helms service manual. Its two volumes about 1100 pages each. They had a couple more manuals I couldn't get before they were out of print;
there is a manual for just the tranny and another for just the
electronics--both out of print now. :sadwavey:
John
