98 Bonneville throttle flat spot
crazy8
04-30-2008, 12:08 PM
Hello again,
Sometimes when turning corners and I'm off the throttle, then resume the throttle after cornering, there is a (flat spot), meaning the throttle response is absent for a couple of seconds then suddenly resumes. No codes present. 3.8 liter v-6 engine
Any ideas?
GTP Dad
05-01-2008, 07:58 AM
Try changing the throttle position sensor and see what happens. You may also want to change the fuel filter just to make sure you aren't getting a temporary blockage due to movement of the filter medium. I would do the fuel filter before the TPS. Much cheaper.
