heads are bad
fuct33
04-18-2008, 12:21 PM
how is possible to tell if your heads are bad besides coolant in your oil
grandprixgtx00
04-18-2008, 12:49 PM
take them off and send them to a machine shop...
inafogg
04-18-2008, 12:58 PM
hello, a compression test of ea. cylinder.a leak down test if you have compressed air.why do u think heads could be bad??yea u can pull the heads but thats a little extreme if your still diagnosing the problem
fuct33
04-18-2008, 07:43 PM
I got a little oil leak right in the middle of motor beneath intake I can see it trickling just cant see where its coming from just wanted to know what prob could be thought it was the heads I dont have coolant in the oil and car still runs great no overheating or anything im lost at what this could be any ideas
inafogg
04-19-2008, 02:30 PM
i would see what else could be leaaking...heads can leak oil but not real common...ck intake manifold,oil switch ect GOOD LUCK
wafrederick
04-19-2008, 08:42 PM
It sounds like around the oil pump drive that takes place of the distribitor,It is sealed with an O ring that dries up and is a very common problem.Most parts stores sell this O ring and is a special O ring.Make sure to lube the O ring up with grease so you don't cut it when putting the oil pump drive back in
fuct33
04-20-2008, 09:28 PM
Thats what I was told today im going to try it my sister had the same problem with her sunbird (same motor) and my dad took it to a shop and thats what it was im going to try it out tommrow thanks
