1996 Olds 88 3.8l Pinging
CBX1980
04-16-2008, 06:32 PM
Hello All,
I'm new to the forum. I just purchased a 1996 OLds 88LS. It has 90k on the engine. It was pinging under the slightest load. I replaced plugs, wires, pcv, and cleaned the egr valve. The service engine light was on. It had a 0442 amd 1870 code. I found a vacuum line that was unplugged, fixed it. I took the ground off the battery while I was working on it. Now no engine light, but it still pings. http://www.oldsmobileforums.com/forums/images/smilies/mad.gif It is not over heating.
Help, any ideas?
Thanks,
Ken G
maxwedge
04-16-2008, 08:29 PM
Welcome to AF. Tough to tell from our desks what this noise may or may not be, assuming it is engine " ping", this is caused for the most part by an inop egr system, either the valve does not work or the exhaust passages to it are blocked.
CBX1980
04-17-2008, 09:30 AM
It is an engine ping. Could the egr system be inop and and the computer not produce a trouble code?
maxwedge
04-17-2008, 03:29 PM
Usually you would get a code but it may take some time to set. Scan it for pending codes.
