Passenger side window in my 2000 doesnt work
highrolla7
04-07-2008, 10:36 PM
Hey! All my power windows work except for the passenger side front window. It is a 2000 4 door Sedan w/ 6 cyl. All others work, so fuse is fine. I have never taken apart the door panels, so not sure what Im up against or what exactly Im looking for. Any help appreciated
Thanks!
Iflylow
04-09-2008, 02:27 PM
I assume you have tried both the switch on the drivers door, and the switch on the pax door.
To remove the door panel, pry out the red reflector in the lower part of the door. Remove the screw. Then use a small screwdriver to pop the plastic cover below the handle off, remove those screws. The handle plastic piece just snaps in, you can pry it out. After that, the panel will pry off. Start at the bottom. You will see two openings to slip in a screwdriver to get started. Once you have the panel off, remove the plastic sheet, and you will be able to get a look at the window motor and wiring.
highrolla7
04-09-2008, 08:53 PM
k, thanks for the step by step. Very helpful. Im not sure what Im hoping for... maybe the motor is bad, or possibly a wire came off or something. I have installed power windows/locks in my zx2, so have some experience with these. thanks again!!
