1995 Achieva S door locks
kerosene25
03-22-2008, 08:59 PM
Just bought this car. The child safety locks in the rear doors seem to work fine. But on both front doors:
-The locks dont lock
-The inside lock switch is loose
-If you put the key in it only goes halfway in
I know I need to replace both front door locks, but I am confused as to whether I just need something inside the door replaced or if the key holes are messed up too? also, if you know the part I need could you post a link to it online?
Thanks
Thanks
xeroinfinity
03-22-2008, 09:50 PM
Welcome to AF.
I dont believe thier is a child lock on the front doors.
I would try some penitrating fluid before replacing them.
They might just be dirty and some lubriction.
Might also try and look inside the key hole to see if a key or something is broke off inside the lock cylinder.
Good Luck and Happy Easter!
kerosene25
03-22-2008, 09:56 PM
i meant to say that the locks and child safety locks in the rear doors work fine. BUT the front door LOCKS ( i know there's no child safety locks in the front) dont work...
The switches are loose like as if theres nothing connected to them inside the door...
xeroinfinity
03-22-2008, 10:42 PM
Ok.
Then you will need to pop out the switch and see if the plug is connected. You may even need to remove the door panel.
Thier might also be a fuse or relay, I'd chekc those too!
