1997 4x4 blazer problems...
tfaber119
03-22-2008, 12:33 PM
ok i just bought a 1997 4x4 blazer, 2 dr, 2 inch body lift, (poor quality lift), 2 inch lift shackles in the back, 3 inch torsion bar tabs lift, pretty much done cheap, but the 4x4 light comes on when you push the button, 4 low dont come on, and 2 dont light up, but the 4x4 doesnot work. i replaced the little vaccuum part under battery because it was torn, and no change. the heater knob that selects vent doesnt work either, seems how both are vaccum am i missing something? the vacuum canister under battery works so i dont really understand this problem, and if any one near me wants to give it a shot to fix it i have 100$ cash, i dont understand it though and im begiing to get frustrated.... thank you..
MT-2500
03-22-2008, 03:11 PM
Run a search on 4x4 shift problems and also.
Go up into the how to.
http://www.automotiveforums.com/vbulletin/showthread.php?t=572914
On that one you can ground pin 13 on the diagnostic connector and read codes on the shift buttons.
Post back any codes.
tfaber119
03-22-2008, 04:49 PM
this is for '98 and newer, mine is a 1997.... so what do i do? is there a way you could give step by step directions on how to eliminat each little problem? i think i have vaccum all the way to my diaphram, it does pull the diaphram closed, but nothing happens, thisis crazy and i cannot comprehend what would encourage an engineer to do some crazy set up like this.... where are you from, and are you willing to diagnose it if i cannot?
tfaber119
03-22-2008, 04:53 PM
what do you mean ground pin 13, and post back codes? like put a ground jumper wire to the 13th pin on the obd2 computer hookup, then watch howmany times the shift light flashes or what... im very confused
MT-2500
03-22-2008, 07:02 PM
http://www.troublecodes.net/OBD2/
Jumper pin 13 to ground or ground pin 13 with key off and turn key on and if you have a transfer case codes they will flash code on the shift button lights.
Count the no of flashes and post back.
MT
tfaber119
03-22-2008, 09:45 PM
ok, i did what you said and it lit up 4high, then they all went out, and the buttons no longer can change it anyway, nothing lights up anymore... did i fuck something up?
MT-2500
03-23-2008, 09:04 AM
If no lights check fuses and power to switch and wiring.
Key on lights should come on or blink one time.
And what ever position the transfer case is in the lightr should come on.
For more information or testing on it your best bet is to.
Get a factory repair manual or a All Data online sub.
http://www.alldata.com/products/diy/index.html
Good luck
MT
tfaber119
03-23-2008, 08:22 PM
yeah, that site is confusing me, im gunna make sure i have good connections, check fuses, then sell it if i cant get it to work, cuz nobody wants to work on this piece of shit...
MT-2500
03-23-2008, 08:30 PM
What part of the site is confusing you?
The all data sub is a copy of the factory repair manual and should led you threw the repair step by step.
Good Luck
MT
tfaber119
03-23-2008, 08:41 PM
it popped up some wierd shit, im so tired of this truck, it has given me hell since day one and it is about to be drug out to the back 40 and burned to the ground..
MT-2500
03-23-2008, 09:08 PM
I use All data almost every day with no problems.
If you have a problem they have great customer support.
Call in or email in.
Or you can always get a factory repair manual.
No pop up or head or weird stuff in a good repair book.:grinyes:
Good luck
MT
tfaber119
03-23-2008, 09:17 PM
my problem is that im not a subscriber, and i have to purchase some membership....
MT-2500
03-23-2008, 09:26 PM
They do not give it away.
But Azone owns all data and gives out some samples on the AZeb site.
But if you want the good stuff Join the club.
24.95$ us plastic and you are set to go in 10 minutes.
If it helps you threw one repair it is well worth it.
Look what it woruld cost to have it done.
Good info is not free.
Unless you go to the public liabary
I pay 2-3K a year for info.
Good luck
MT
tfaber119
03-23-2008, 09:27 PM
i also have a non functioning heater vent knob, its stuck on defrost, knob moves but no result, which points me to think vacuum, but the vacuum controlled diaphram seems to be shrinking up when the button is pushed.. this is alot more then i bargained for...
tfaber119
03-23-2008, 09:30 PM
yeah, but at 17 years old, truth is i probably wont end up fixing it, then it will go to a mechanic, so itll be 25 extra in the end, because i have a lack of patience for newer cars... shouldnt they be better then old stuff? my 85 s10 with a 400 horse 350 doesnt give me this much trouble and i assembled it at the age of 15....
tfaber119
03-24-2008, 01:53 PM
well i found a friend with alldata, and i have it narrowed down to "repair ground ckt" or something like that.. what does this mean? thanks alot in advance
tfaber119
03-24-2008, 01:58 PM
ok... could someone give me a non technical definition of the system? what happens with the vaccuum diaphragm? what do the buttons do? does the vac pull a cable that shift the front axle setup? what is the system simplified? are electronic parts involved near the differential?
MT-2500
03-24-2008, 02:47 PM
If that is what all data says.
Go for it.:grinyes:
All of the repair info and wiring and ground circits is in the all data repair info.
Make that friend you buddie for life or as long as he has the all data.:grinyes:
MT-2500
03-24-2008, 02:51 PM
The front axel gets locked in by the front axel actuator.
The push buttons tell the 4W transfer case shifting computer to shift the transfer cas from 2W to 4W drive.
Go threw the all data it tells all about the system.
Good Luck
MT
tfaber119
03-24-2008, 03:02 PM
yeah but what does that mean in non technical term, and how do i do it?
MT-2500
03-24-2008, 03:11 PM
If you have it narrowed down to a bad ground or ground circuit repair the ground on that circuit.
Clean and check the ground and check with a volt /ohm meter.
A ground wire should not have any voltage on it.
If it does it is not grounded.
MT
tfaber119
03-24-2008, 09:48 PM
what is circuit 13? wher is it? do i ground it to the body or frame? whats the easiest way?
MT-2500
03-25-2008, 08:34 AM
Pin 13 on the OBD11 diagnostic connector.
Pin 13 is wired to the transfer case module.
I posted a picture of in in the link.
It puts the transfer case module in diagnostic mode to get code,
Ground it to any good ground and turn key on.
Good luck
MT.
tfaber119
03-25-2008, 02:01 PM
ok, i misread the directions, it say circuit is grounded, like power is grounded out somewhere but where is most common?
MT-2500
03-25-2008, 03:56 PM
Where are you at on it?
What are you checking?
What says circuit is grounded?
If you are still checking for codes .
Jumper pin 13 to pin 4 as in picture.
tfaber119
03-25-2008, 04:41 PM
i dont have a lift, but thursday ill be working on it, ill ground the 4 pin and the 13 pin.... together and see what the problem is, but what else can you do to narrrow this search down...
tfaber119
03-26-2008, 01:51 PM
my buttons are pretty crappy, the 4 hi looks like someone tried to kick the button into gear, however it is the only one that lights up... but they all dont light up now, and could my problems be right there? is that possible to cause all these problems?
MT-2500
03-26-2008, 02:37 PM
key on all buttons should light up for a bulb check if not
Check the push button switch and bulbs.
MT
