01 Hub and bearing question
tempfixit
03-17-2008, 09:19 PM
Friend has a 01 Intrepid that as you are driving it has a sound like a drum is rubbing someplace (you can hear it every revolution and increases with speed) but when the brakes are applied the sound quits. Looking at a online manual it talks about a FLINGER DISC on the front hub and bearing assembly. What is this FLINGER DISC and could the rubbing sound be coming from this???? I have not taken car apart yet to find problem which I thought might be a bad bearing on the rear but knowing now that it has 4 wheel disc brakes I am stumped.
IF anybody knows where I can find a picture of the FLINGER DISC on the hub and bearing assembly that would be great.
Thanks for any suggestions.
punisher808
04-02-2008, 11:26 PM
i had same problem(assuming we're talking about the rear wheels)with rubbing noise. couple weeks later i was reversing into a parking stall at work and the rear brakes locked up totally on their own....long story short..check your e-brake integrity..pull the rear hubs and make sure all your springs and hardware are in tact.
punisher808
04-02-2008, 11:28 PM
the rear has disc primary breaking system...and drum parking break on the inside of the discs.
tempfixit
04-03-2008, 12:03 AM
thanks punisher808, I was thinking possibly something in that line but why would applying brakes quiet it when the parking brake is not affected by braking?
I will have to pull rear wheels and check for potential problems you refer too.
Thanks again
punisher808
04-03-2008, 12:14 AM
not sure why it got quiet when the breaks were pressed...i have an intrepid..its my first dodge.im not overly impressed with it
