dome light (light stay's on to long)
andthisismysn
03-14-2008, 05:07 PM
i have a 95 blazer. the dome light stay's on a little to long. Dose anyone know how to adjust the light to shut off when i close the door? or lower the time it takes to shut off?
MT-2500
03-14-2008, 05:31 PM
How long is to long?
Does it always turn off?
Right bulbs in it?
Does it have the keyless entery system?
Remote start or add on antitheft stuff?
andthisismysn
03-14-2008, 07:27 PM
long enought to make me wait to back up. i can just pull the bulb,but i just want the light to shut off when i close the door. i was just looking to see if anyone knew if there were a e-z change to it.
MT-2500
03-15-2008, 09:09 AM
Some have a built in delay.
Check what the delay time is in sevice manual and time yours.\MT
andthisismysn
03-17-2008, 09:42 PM
where is the timer?.
MT-2500
03-18-2008, 08:47 AM
You have not told us how long the delay is.
Doe it have a keyless entery system?
Oldsmobile Doctor
03-18-2008, 01:31 PM
The Interior Lamp Control Module (timer) is located at the lower center of the Instrument panel. It will have 5 wires coming from it Pink, Orange, White & two Black ones. you can get a replacement to fix time problem or clip the white wire. If you clip the white wire the lights will go off as soon as the door is shut and not go on when you lift the outside door handle. The keyless entry could also cause the light to stay on. I worked on a Bravada that the lights would sometimes stay on and kill battery and sometimes not I just cliped the white wire.
andthisismysn
03-18-2008, 06:09 PM
it only stays on for a min.
MT-2500
03-18-2008, 06:17 PM
That is about normal.
As long as it always goes off.
But you can always chop it out of there as perscribed by Olds Doctor.
MT
andthisismysn
03-18-2008, 06:31 PM
thanks every one, the doc perscribed the right med. lol
