No Brakes in Rainy Weather
DonD78217
03-14-2008, 01:23 PM
I searched the FAQ for my problem with no results.
My brake pedal is normally low (1 1/2 inch of floor when brakes applied). The other day was damp with light rain. My brake pedal went to the floor with minimal braking. Pumping didn't help. Brake fluid is OK. Now the weather is sunny and the brakes work as they always do.
What happened ??
What happened ??
MT-2500
03-15-2008, 12:05 PM
Welcome to AF.
Any brake or ABS lights on when it does it?
MT
MT
DonD78217
03-20-2008, 03:03 PM
Thanks 4 the reply..
No !! No lights. No nothing out of ordinary.
MT-2500
03-20-2008, 03:41 PM
You may have it tested when it does it with a ABS capable scanner..
And test for stored abs codes before turning the engine off.
Good Luck
MT
Good Luck
MT
DonD78217
03-25-2008, 12:10 AM
Thanks. It rained again last week and the brakes were OK.
It must have been a fluke.
MT-2500
03-25-2008, 08:27 AM
You are welcome.
ABS Acting up in damp or rain is usually the a wheel speed sensor or wiring getting wet and shorting out.
Good Luck
MT
You are welcome.
Good Luck
MT
