Heat/AC blower not working (1993)
mmcginnis46350
03-14-2008, 12:15 PM
I can't seem to get my blower for heat and AC to turn on. My car sat for a couple of months this winter and when I went to start the car it wouldn't turn on even though the climate control says the fan is on. I checked all fuses and that doesn't seem to be the problem. I did get it to start for a couple seconds when I first started the car but it stopped and won't start again. When driving the heat seems to be working but just no blower. Any suggestions?
olecuzz
03-20-2008, 02:38 PM
Exact same problem here also. Is the Blower Motor dependant on the Blend door operation?
Olecuzz...
Olecuzz...
Towncar
03-20-2008, 06:48 PM
Blend door isn't the problem, this time...
Check your Blower Speed Controller.. There's a large transistor on a circuit board inside there, it comes loose. A bit of good solder should have it running again.
olecuzz
03-20-2008, 07:41 PM
Actually... I just found the problem. Got to looking around on the web and found this.. http://www.lincolnsonline.com/tech/00067.html . I done this and that fixed the problem.
