2000 astro valves!!!
louie vulgar
03-10-2008, 12:52 AM
i recently took my van in for a dtc p0306, plugs, wires, cap, rotor were changed prior to taking to shop. The mechanic said my injector was bad, replaced the injector and fuel pressure regulator. then he told me that I needed a valve job because they were shot! how can I make sure the valves are done??? please help!
Headnsouth
03-10-2008, 06:43 AM
Whats the reason doing a valve job? Why does he say they are bad?
Do a compression test to evaluate the condition.
louie vulgar
03-10-2008, 11:27 PM
he did a compression test, and said it was good but he hears a noise, the van makes a noise and it idles rough and only does at operating temperature and at slow idle speed.
Headnsouth
03-11-2008, 05:39 AM
Is the mechanics name Kreskin? :D
What kind of mileage, maintenance has it had?
#06-06-04-046: Information on Engine Misfire MIL/SES Light Illuminated or Flashing DTC P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, P0420 or P0430 - (Sep 12, 2006)
Subject: Information on Engine Misfire MIL/SES Light Illuminated or Flashing DTC P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, P0420 or P0430
Models: 1999-2007 Cadillac, Chevrolet, GMC Full-Size Pickup and/or Utility Trucks
with 4.8L, 5.3L, 5.7L, 6.0L or 6.2L VORTEC GEN III, GEN IV, V-8 Engine (VINs V, C, T, Z, B, 3, M, 0, J, R, U, N, Y, K, 8 -- RPOs LR4, LY2, LM7, L59, L33, LC9, LH6, LMG, LY5, L31, LQ4, LQ9, L76, LY6, L92)
with Active Fuel Management™ and E85 Flex Fuel
If you encounter vehicles that exhibit the above conditions, refer to SI for the appropriate DTC(s) set. If no trouble is found, the cause may be due to an ECM ground terminal that has corroded with rust over time. Inspect the main engine wiring harness ground terminal (G103) for this condition.
The wire terminal (G103) attaches either to the front or to the rear of the right side cylinder head, depending on the model year of the Full Size Pickup and/or Utility Trucks. If the ECM ground terminal has been found to be corroded, then follow the service procedure outlined in this bulletin to correct the corrosion issue.
Vinnie6
03-16-2008, 09:25 PM
I had a tick but it was a lifter. I only heard it when going through the drive through and heard it echoing off the building.
