95 pickup engine dies when starter stops
harrywat
03-04-2008, 12:28 AM
Hi folks
The engine starts fast and I can increase speed as long as I keep the switch in the start position. When I let the switch go to the run position, the engine dies.
I had flushed the cooling systen the day before. I had the upper and lower radiator hoses and both heater hoses disconnected. It started and ran for about 20 seconds on the first try and has not repeated since.
Its a six cyl, Any ideas?
Thanks
Harry
fourwd1
03-04-2008, 08:54 PM
Are you saying you start the engine, then keep the key in START and step on the gas?
That can't be good for the starter.
harrywat
03-04-2008, 09:55 PM
I can't disagree with that, but I did it quickly to verify my problem was not fuel. Any ideas on what my problem is?
Thanks
Harry
