2002 Alero Front Wheel Rubbing Soft Grinding noise
jratism
02-26-2008, 08:17 PM
Another 2,000 miles another Alero problem
My 2002 Alero has a distinct Rubbing /Soft Grinding pulsating noise coming from the front drivers side wheel. (best guess) its more pronounced as the car slows and even more so when I brake or turn the steering wheel. The Front Rotors, Pads , Hardware and Calipers were done 11,000 miles ago (May 05) and the Left Front Wheel Bearing Harness was done less than 8,000 miles ago (01/06).
Also, Right Front Harness done 5,500 miles ago (05/06). Back Rotors and Pads done 9,000 miles ago (11/05).
Any idea what this could be? Certainly not the front brakes again? Jeez Louise! This car is a money pit.
Thanks for any help you folks could give.
J R
J R
BNaylor
02-29-2008, 09:19 AM
When you did the brake job were the rotors replaced or turned down?
jratism
02-29-2008, 10:16 PM
BNaylor:
The Rotors were replaced.... at Midas where there is a pad guarantee...
Wondering if it has something to do with the Power Steering? Some previous threads mentioned this. The fluid was low.....but not that bad....which means a leak possibly. I topped it off and it seems better.
Thx
Thx
