newly acquired 1997 88 need help with a few issues
rnj
02-26-2008, 05:05 PM
First, antenna does not completely go down, cleaning resolve, or is it toast.
Second, seat recline does not work, front and back up and down work, just recline does not. relay???
third, is there a cruise control light on dash to let you know cruise is engaged?
Last, The car was driven up from FL. and regular antifreeze was added, less than a pint, to top it off. need for a flush right away???
Thanks!!!!!
maxwedge
02-27-2008, 05:30 PM
The antenna may be slightly bent or the staff could need some lite lube. The seat switch could be bad or one of the solenoids, I do not think there is a cruise lite, check the owner's manual. Get a coolant test done for strength, I would flush and change it just anyway to bring the car up to a known maintenance level.
rnj
02-27-2008, 07:33 PM
thanks for the reply. I was out looking at the car and the antenna was bent, I straightned out enough to smoothly go up and down. antifreeze was tested and is within specs. I still feel I will flush. And the seat I will need to mess with another time, when it gets warmer out. Were are the solenoids located for the seats?
maxwedge
02-28-2008, 03:16 PM
Under the seat part of the seat motor transmission assy..
