How do you replace turn signal lever
winston3338
02-12-2008, 12:24 AM
Does anyone know How do you replace turn signal lever for a 1994 olds cutlass supreme? It controls the Turn Signal / Cruise Control / Tilt Lever, Wipers, Brights.
Thanks in advance.
http://i112.photobucket.com/albums/n180/winston3338/turnsignallever.jpg
Thanks in advance.
xeroinfinity
02-12-2008, 06:24 PM
Yeah its no fun, try this link here (http://www.autozone.com/az/cds/en_us/0900823d/80/0e/d7/7a/0900823d800ed77a/repairInfoPages.htm).
winston3338
02-12-2008, 08:19 PM
Thanks for the reply. I just pulled on it lightly and it popped out and I put a used one in and a new signal cam and a new signal lever and still the same problem and that is I have to turn on the left blinker to get the wipers to work. Good old American cars.
xeroinfinity
02-13-2008, 05:31 PM
You need to replace the part inside the colum cover, that part that the arm goes into is whats bad, not the lever.
winston3338
02-13-2008, 05:39 PM
You need to replace the part inside the column cover, that part that the arm goes into is whats bad, not the lever.
Hi xeroinfinity, Thanks for the reply. Yes I did find out that the
"multi-function lever assembly" is bad but I don't want to go through the trouble to find one or figure out how to replace it.
I live in Las Vegas and it don't rain all that much. If the wiper problem gets worse I am going to cut the slow speed wiper wire at the motor and just put in a toggle switch. It took about $400.00 but I have My rear brake and blinker lights again.
xeroinfinity
02-13-2008, 05:49 PM
that whole switch new didnt cost any where near $400, about $200 ish for a MFS.
Good Luck
Good Luck
winston3338
02-13-2008, 06:10 PM
that whole switch new didnt cost any where near $400, about $200 ish for a MFS.Good Luck
Guy it wasn't the multi-function lever assembly in the beginning. I had the famous one brake light and third brake light working and that was the turn signal cam that cost almost $300 with labor and then the turn signal lever and labor that was over $100. I won't even bother with the multi-function lever assembly. Just not worth the time or money. I will turn the left blinker on for a second when I need the wipers to wipe. Thanks for taking the time to reply.
xeroinfinity
02-13-2008, 08:41 PM
sorry about that I miss-read your previous post. :uhoh:
