92 isuzu v6 won't start
jviox
02-07-2008, 12:36 PM
relaced battery cables,fixed problem 4 a week, it will jump start with cables after numerous tries? now won't jump at all......clicking noise on starter fuse? replaced didn't fix I have full battery power? would it be starter?.......HELP PLEASE on problem and how to remove starter if this is problem....not a mechanic so need all the help I can get. v6 engine on na ls trim.
amigo-2k
02-07-2008, 12:45 PM
If you have a good battery and good connections and all you are getting is a clicking sound from your starter,then my guess is the start is gone.
jviox
02-07-2008, 12:58 PM
ryan, the clicking noise is from the fuse(panel in engine compartmen?) not the starter?
jviox
02-07-2008, 01:03 PM
doesn't make sence????? I jumped it this morning...........then got to work wouldn't start..........1 half hour later I got it to jump.....with cables on......then it just fired................but when it did it sounded like a low battery start......slow
andrew_j
02-07-2008, 02:27 PM
check your starter, as previosuly stated.
amigo-2k
02-07-2008, 07:05 PM
That slow start is another key sign. It did the same thing on my old S10. Slow start for about 3 days and then it was dead.
