Honda 2003 Alternator Problems??
mdc924
02-05-2008, 09:49 PM
I had to get a new alternator for my Honda 2003 Accrod. Thought it was the battery, but after it was jumped and I was driving it, different dashboard lights were coming on and off then the died on me and it had to be towed. It will cost me (at the dealer) $539 parts and labor. What has anyone else paid? I checked the internet and saw that honda alternators parts for $266..so labor is that much to install it?:banghead:
mdc924
02-05-2008, 09:50 PM
nm.
somick
02-06-2008, 12:37 PM
If your question is about alternator, yes dealer wants money!!!
Since you you have installed a new alternator and your question is about a warning light, describe what light and what it says.
Autozone will read codes for free.
Good luck,
Sam
Good luck,
Sam
mdc924
02-06-2008, 11:39 PM
After I got my battery jumped, I thought I only had a dead battery. After that, while driving the car, various lights on my dashboard would come on and off, but the engin icon light stayed on. But the ABS and brack lights would come on and off. Then my car died and a jump would not fix it. It was towed to the dealer and after a few hrs called to say it was an alternator problem. So question is shouldn't an alternator last longer? I had no warning in prior weeks days this may happen. Any thoughts??
mpumas
02-06-2008, 11:57 PM
Sounds like a over voltage caused by the bad alternator. Alternators should last at least 100K miles. Threre may be other problems caused by the alternator. Dealer alternators can cost $300+ plus a couple hours of labor to replace.
somick
02-07-2008, 01:47 PM
On my 99 LX the alternator is right there at the top of the engine. You need to undo two bolts and it will be out. Probably it is different on 2003.
mpumas is right: alternators should last you at leas 100,000 unles you overloaded it.
The symptoms described above sound like a bad ground to me. But if the alternator has been already replaced not too much you can do.
Sam
Sam
