mpg help
n_i_c_k
02-05-2008, 04:04 PM
i have a 91 civic lx d15b2. Recently it has been getting piss poor gas milage. Normally even in winter it gets around 36mpg, but in the last 5-6 months it has dropped to around 22mpg. I figured it needed a tune-up, so i have replaced the spark plugs and wires, distributor cap and rotor, and any thing else i felt necessary to replace.
Does anybody have any clue what the problem may be?
tepco
02-05-2008, 07:39 PM
The only other thing i can think of for a basic tune up that you didnt mention was an air filter.
Another good place to look is your cat, if it's clogged it can effect your MPG. A good resource is www.gassavers.org alot of guys drive Hondas there.
Good luck.
Greenblurr93
02-05-2008, 08:00 PM
check tire pressure, change fuel filter
n_i_c_k
02-05-2008, 08:10 PM
i have changed all filters and tires are in near excellent condition. i will check the cat though.
Greenblurr93
02-05-2008, 08:12 PM
it doesnt matter what condition the tread is in.... Im talkin about the air pressure in the tire, as the weather gets colder in the winter, the air pressure in the tires will drop, resulting in poor gas mileage... I would check to make sure all the pressures are up to spec
n_i_c_k
02-05-2008, 09:16 PM
i check my pressure almost every fill at the gas station and it is usually in spec. sorry for not giving a valid answer before hand. i did discuss the problem with my brother and he mentioned the possibility of slipped time. any ideas?
FrodoGT
02-05-2008, 10:34 PM
Change your oil..old oil is a power robber.
Greenblurr93
02-06-2008, 07:29 AM
Timing could also be the issue.
Christ
02-08-2008, 12:17 AM
timing, oil, tire pressure, although that won't make you lose 10+ mpg... check ignition timing, since you just replaced the cap/rotor, it could be off a couple degrees... recheck plug gap, check cam timing, check/replace timing belt.
