Injector valve 1 low voltage c20xe
xemo13
02-04-2008, 12:53 AM
:shakehead Please help me! my astra 1993 Gsi 16v (c20xe) has failed co emmisions in MOT (too high readings that get higher as it revs up). a fault code has come up and I used the "paper clip" method and read code 81 which means "injector valve 1 low voltage" Shall I replace the fuel injectors or what? How can I solve the problem?
Boroboy
02-05-2008, 02:51 PM
This forum should be of some help to you:- http://www.vauxhallownersnetwork.co.uk/forumdisplay.php?f=83
xemo13
02-09-2008, 02:04 AM
thanks for the advise. I'll check and hope to find the answer
Boroboy
02-09-2008, 09:31 AM
No probs, It's a dedicated Vauxhall forum. I've used it in the past when I've had probs with my Astra.
