'97 jimmy intake man. leak/lifter noise
DaVeMoE
01-31-2008, 08:01 PM
I read the "tech" article about the repair for this problem,and I was wondering how long can I let this go?(through the winter?),and second, is will the lifters need to be replaced?(they chatter for a few minutes until they pump up). I am not reluctant to do the job because of the work involved ( I did an intake man. job on a '95 k2500), I would just like to do it in warmer weather if I'm not going to smoke anything before then. What do ya think? Dave
old_master
02-01-2008, 06:10 PM
Coolant in the oil will cause internal engine damage. Don't wait, repair it ASAP.
DaVeMoE
03-24-2008, 08:24 PM
Just wanted to finally post an update to my original post on 2/1/08.
I did replace the intake manifold and valve cover gaskets shortly after the post, took about 15 hours total, $60 (approx.) in parts and unknown amount of money to heat the garage in the middle of winter ,but I did save approx. $800 (the cost a local shop told it would be).
A word to the wise.. do not cheap out on the gasket kit , I bought Fel-Pro!! Changed the oil and coolant after I was done and all is well !! The lifters even stopped making noise after a couple of driving cycles.
p.s. don't overlook the inevitable carbon build up on the bottom of the injectors ;)
