01 Oddyssey Transmission fluid change?
karnovking
01-31-2008, 06:09 PM
So I don't have to go out in the freezing cold and get under the van, can anyone tell me if this vehicle has a pan or a plug?
wiseguy01
01-31-2008, 09:30 PM
im pretty sure that all hondas have a plug that takes a 3\8ths ratchet
rodeo02
02-23-2008, 06:41 PM
Yep, the Honda 5spd auto should have a 3/8" square drive drain plug and I believe a 17mm hex head fill plug on top of the case.
Joel
karnovking
03-11-2008, 06:56 PM
I found out the vehicle got a new transmission 500 miles before I bought it YES!!!! No need to worry about a fluid change for a while. THanks anyway guys
rodeo02
03-12-2008, 08:31 AM
Sweet deal! I'd still do a drain/fill cycle or two in a few months just to purge any break-in debris that *might* be present. Honda didn't officially add an external filter until 2002. Check to see if they added an inline filter on the cooler return line on yours. They should have.
Joel
