Rear brakes... smoking
purepower77
01-28-2008, 07:34 PM
I replaced the rear brakes on my lumina, and now they're burning... it seems like they're in constant contact with the rotor... too tight. Any ideas what I did wrong? It's on BOTH sides. I went pretty far... should I have pushed the pistons in a little further? I figured they'd set themselves to the correct position as long as I could get the pads over the rotors...
Any help would be greatly appreciated.
Bearwulf
01-28-2008, 10:15 PM
What year is it? Most of the Luminas with rear disc you must screw the piston back into the caliper, not just push it.
purepower77
01-29-2008, 06:45 AM
It's a 1993, but when I said 'pushed', I was just speaking generally. I did screw them in.
I had to mess with the actuator screw a little to be able to be able to rotate the pistons back in... is that what's causing the problem? Do I need to adjust the actuator?
Bearwulf
01-29-2008, 10:28 PM
I was kind of tires last night, You should always screw the pistons all the way in. They can't loosen themselves, only tighten.
j cAT
01-31-2008, 06:56 PM
sometimes the pads need filing to fit properly. if they set too tight or have burrs where they stamped the metal backing plate , they can stick. also you must bleed brakes . some think this is not neccessary but they have problems when their caliper pistons seize.
