Alternator not charging??
nozelle
01-27-2008, 01:49 PM
I have a '97 GT3000 which appeared as if the alternator wasn't charging the battery. I had the alternator rebuilt and the voltmeter still read anywhere form 10-4v!. I replaced the alternator to get the same results to my dismay, low voltage reading. I checked battery negative and positive wiring, all seems well, tight no loose connections.
Recently the battery died (the voltage meter was reading 0 with the car running) so a borrowed a battery to get a jump. After the car started with my friend's battery it shutdown when the battery was I disconnected from the terminals. This happened again on subsequent attempts. I had to borrow the battery to get the car home!
During troubleshooting the CHECK ENGINE light came on but after disconnecting the battery. Diagnostic check revealed no error codes.
I know typically the shutdown of the engine when the battery is disconnected is indicative of alternator problems, but 2 alternators? Just thinking outside the box could this be another problem-grounded wiring somewhere, a blown fuse?
The GT has a bulldog security system installed-this is the only major electrical change made to the vehicle. Help is desperately needed guys. Thanks.
new2mitsu
01-27-2008, 10:18 PM
it really seems like you have a short somewhere
Stealthee
01-27-2008, 11:13 PM
Check to see if the altenator fusible link in the fuse box is blown. If its blown the alt cant charge the battery.
nozelle
01-28-2008, 07:03 PM
Thanks for the info-I try the suggestions and see what I come up with. I'll keep you posted.
