97 Tahoe P1345 Service Engine Code....
BiggWaukegan
01-20-2008, 01:38 PM
Guys please help me out here. My 97 Tahoe seems to be running fine but today the Service Engine Soon light came on. Took it to autozone and they checked the obd2. Code came back p1345 for camshaft to crankshaft position correlation fault. THE HELL DOES THIS CODE MEAN? WHAT DO I NEED TO FIX????:banghead: Please help me out
MT-2500
01-20-2008, 04:50 PM
It means the dist rotor pointing is not set dead on with the spark plug terminal.
You will need to find a good engine capable scanner trhat will read the camshaft retart setting and adjust the dist to read as close to 0 degrees
as you can get it. if reading over -3 or +3 camshaft retard it will set the code.
Has the dist cap or rotor or dist been replaced latley on it or how long has the light been on?
MT
MT
BiggWaukegan
01-21-2008, 10:32 AM
Had a tune up done bout 5 months ago. Dist. cap , rotor and wires plugs all that sht was done. But its ran fine since then . No lights or anything. Just all of a sudden on Saturday when I started it the check engine light was on. Been on since then. So maybe I need to have the engine Timed?:banghead:
MT-2500
01-21-2008, 10:35 AM
The engine timing is not adjustable.
Only the dist camshaft retard that has nothing to do with the timing.
MT
MT
BiggWaukegan
01-21-2008, 10:40 AM
ok then what are you saying to fix mt. The dist.?? the crankshaft postition sensor?? what ??:banghead:
MT-2500
01-21-2008, 11:05 AM
Go back and Read post 2.
MT
MT
777stickman
01-21-2008, 11:22 AM
The "cam retard or offset" mode is kind of like a "base" timing mode. This mode puts the CMP (cam position sensor) and CKP (crank position sensor) in sync with each other. The P1345 is telling the VCM that the 2 are out of sync.
Possible causes.
1. A loose CMP in the dist.
2. Excessive play in the timing chain and/or gear assy.
3. Dist installed wrong. One tooth off in either direction.
4. Loose rotor on the dist shaft. If the rotor turns on the dist shaft the dist needs to be replaced.
5. Loose or missing dist hold down bolt allowing the dist to turn.
The timing can only be checked and set with a scanner that is capable of getting into the cam "offset" or "retard" mode. Timing should be 0 +/- 2 degrees with engine rpm's at or above 1000.
If engine speeds are varying the CKP could be the problem.
Possible causes.
rbsweet
01-26-2008, 03:11 PM
I think I have the same problem on my 1996 Tahoe, though I haven't taken it in to see if the P1345 code is coming up. About 4 times this past year, we've driven somewhere, run an errand for an hour or so, come back to the car and it won't crank or start. No clicks, no noise from the engine - nothing. After sitting there for 40 minutes, I'll try it again and it fires right up. Just put in a new battery and they checked alternator, starter, etc. - all good. Is this the crank shaft alignment problem, or just a bad ignition switch?
maxwedge
01-26-2008, 03:31 PM
Welcome to AF, usually some connection between the ign and the starter, not the sensor here.
hgerrick
02-03-2008, 07:56 PM
I recently purchased a 99 Suburban that is giving me a fit. I changed the intake manifold gasket and had to play with the position of the dist. to get it to run right after that. I took the truck on a 1200 mile trip after that and about 120 miles from home it just started to miss again. The next day drove it and it ran fine until it went closed loop then it ran BAD, really missed. It seems to run a ok until it goes closed loop then sometimes not too bad, sometimes really bad. But the first question is; I have read it until I can repeat frontwards, backwards in my sleep the procedure for setting the camshaft offset retard dwell, but have yet to see mentioned one time a scan tool that will read this. Is the dealer the only place to get this done? Quote" the camshaft offset has to be set blada blada blada.... but no, use this scan tool to do it!!!!!!!!!!!!!! I would love to at least know how much I have to spend to own one that will do it, I am considering buying one anyway. Any help??
Thanks, HG
Thanks, HG
MT-2500
02-04-2008, 09:07 AM
Thanks, HG
Welcome to AF
It is best to start a New thread/post with your problem.
Saves hyjacking someone elses post.
Dealers or good repair shop have the good scanners.
High end Engine capable scanners are required to set the camshaft retard.
They start at 3 grand up.
There is a lot of lap top programs out that may do some of it.
Check and ask around.
MT
Thanks, HG
Welcome to AF
MT
hgerrick
02-04-2008, 05:55 PM
Sorry, I don't want to hijack the thread. But if I had a nickel for every post I read all over the internet in the last week since I started having this problem, telling me how to set the camshaft offset.....and not one telling me the tool to use, I could buy a new truck!!!!! It got the best of me.
Thanks, HG
Thanks, HG
Kennykbe
05-11-2008, 10:43 PM
Just had this on my '02 Silverado with the 4.3 V-6. The distributor gear was worn pretty bad. The gear was about $60 and had it replaced in less than an hour. The motor had 77,000 miles on it. A GM mechanic friend of mine told me after the fact that its a pretty common problem
MT-2500
05-12-2008, 09:00 AM
Remember after a dist R&R always check and set the camshaft retard with a good engine capavble scanner.
Also when repacing the gear and or dist make sure the gear is set right on dist shaft.
You can get the 180 degrees off which will mess up the none adjustable dist.
MT
MT
black 97chevytruck
09-09-2008, 10:42 PM
i had a technition run a dtc reader on my 5.7l truck, and one of the things that came up was that the camshaft and th crank shaft were out of sync, i dont no wat kind of problems that can create, but can someone please help me, and tell me how to fix this.
MT-2500
09-10-2008, 09:13 AM
Welcome to AF
This post is old and has already been high jacked several times.:lol2:
Always check the date on a post and let it rest is it is over 30 day or more old.
For you problem read the replies in the upper post.
Also always start a New Thread/Post on your own problem.
If you need help on it.
And someone will help you.
Good Luck
Welcome to AF
Good Luck
yukon6inchlift
12-07-2008, 07:13 PM
Welcome to AF
Good Luck
another non helping thread on dist and timing probs on P.O.S gm vortec
Good Luck
