No clutch slave?
Crxce
02-20-2003, 08:33 PM
The 88 rex doesnt have a clutch slave im pretty sure so that means the clutch pumps off the brake master cylinder.
GTA
02-20-2003, 08:36 PM
there is no slave clyinder. Its not a hydrolic tranny which requires a slave clyinder.Its a cable tranny, it actuates the clutch by cable
Crxce
02-20-2003, 08:43 PM
but if my clutch was low on fluid or i wanted to check the fluid were would i check what would i do?
change the brake fluid?
GTA
02-20-2003, 08:49 PM
your clutch cant be low on fluid. There is no fluid controling it. If its not engaging properly you might need to adjust the cable, or might need a new clutch.
Crxce
02-20-2003, 08:53 PM
oh alright so then a hydrolic tranny has a clutch slave wich contains fluis and a cable tranny has no fluid what so ever so to adjust the cable its under the hood right
GTA
02-20-2003, 08:57 PM
right.
Jmunk
02-20-2003, 09:27 PM
The only fluid in your drivetrain is your tranny oil.
Crxce
02-21-2003, 09:59 AM
thanks for clearing it up
Tony
02-21-2003, 12:14 PM
Does anyone have a how-to on adjusting the clutch? If not, I'll try and get my friends digi cam and take some pics so we can get a how-to on that up. quite simple to do, but hard to explain what you have to mess with.
