91 2.0L Turbo fuel cut question
tempfixit
01-16-2008, 11:08 PM
91 Turbo 2.0L 5 Speed Manual Trans.
The egine cuts out @ 5000RPM, I am assuming it is the fuel cut. What would cause this. Air leak somewhere or is it wastegate related??
Thanks for any advice
vanilla gorilla
01-16-2008, 11:24 PM
Is it stock or modded? If so, what mods?
tempfixit
01-16-2008, 11:47 PM
Neigbors car. No mods that I am aware of. The caps went bad on the ECU lately, geeted the ECU rebuilt now (non eprom). Has high idle at start up and surging idle until warm I have been told.
Thanks
Thanks
gthompson97
01-17-2008, 05:01 AM
A stock car should not get fuel cut. Have you done a boost leak test?
SilvrEclipse
01-17-2008, 08:50 AM
I think most cars have a little idle surge when they are cold. If it stops when warmed up then I wouldn't worry about it.
kjewer1
01-17-2008, 09:46 AM
When a stock old ass 1g starts surging, first things that come to mind are failed or misadjusted throttle closed switch and bad ISC. For fuel cut, the boost leak test is the best suggestion for a good start (might even accidentally fix the idle surge by fixing any post TB leaks).
tempfixit
01-17-2008, 07:06 PM
Thanks for advice on Boost Leak Test. Never done this before so I will search for details on how to do this.
Where is the throttle closed switch?
I have checked ISC with a ohm meter and got 26.6 ohm's on all 4 tests.
kjewer1
01-17-2008, 08:19 PM
It's a switch on the far (firewall) side of the TB, single green wire IIRC. The switch is NO, and when closed provides a ground through the TB. Make sure the ground wire is attached to the throttle cable bracket from the firewall.
tempfixit
01-18-2008, 12:11 AM
Thanks, I will check the wire and make up a boost leakdown tester and test when the weather gets a bit warmer here in WI. I post results.
92talontsiawd
01-19-2008, 08:10 AM
i get a fuel cut out around 5500 also.. how would u perform a boost leak test? lol prob a dumb question but im new to boosted cars.
tempfixit
01-19-2008, 09:06 AM
Read this page it should help you:
http://www.vfaq.com/mods/ICtester.html
This site has lots of great info for newbie dsm owners:
www.vfaq.com (http://www.vfaq.com)
I haven't done a test yet but will when it warms up -12 right now in WI.
Hope this helps
Hope this helps
