1990 cherokee cruise control
hotrod39
01-15-2008, 04:34 PM
cruise control does not work, is there a relay for it or a common problem i should investigate first.
hotrod39
01-22-2008, 11:15 AM
no-one wants to touch this one huh?
AlohaBra
01-23-2008, 08:36 AM
See if this apply to your year. I am more familar with late model electricals.
http://jeep.larrynova.com/88/cruise_control_system.pdf
hotrod39
01-23-2008, 11:31 AM
if it ever warms up, -20 with wind chill, i will use this to troubleshoot, thanks for the info
Saudade
01-23-2008, 03:17 PM
The Cruise is both electrical and vacuum operated. You could merely have a vacuum leak. How's your heater doing?
hotrod39
01-23-2008, 05:22 PM
there are heater control issues that i havent had the chance to shoot. everything is on weather hold. i believe these to be vacuum related, may be affecting the c.c. as well
Saudade
01-23-2008, 07:07 PM
Could be. While the "speed control" is electrical, the actuator connected to the throttle cable is vacuum operated.
Check under your battery (remove the battery tray) for any holes in the lines.
There's also the vacuum bottle located behind the front bumper.
