2003 F250 Gauges Don’t Work
cknadroj
01-06-2008, 01:17 PM
I’ve searched this forum but can’t find an answer.
Instrument cluster it lit, but none of the gauges work.
Everything else seems to be working normally.
Checked Fuse Nos. 35 and 41, both OK and have 12VDC.
Anything else I can check?
Davescort97
01-07-2008, 03:54 AM
Check for loose ground wire on the back of the instrument cluster.
cknadroj
01-07-2008, 09:32 AM
Turns out its a known fluke - fouind out on another forum.
Apparently, sometimes when the engine is cold and the O/D is turned on/off via the button on the shifter fuse no. 45 blows.
Replaced fuse and all better now.
cknadroj
01-07-2008, 08:30 PM
Not all better. Fuse 45 blew twice today.
cknadroj
01-11-2008, 10:46 AM
My overdrive cancel switch wires wore through inside the steering column cover - easy fix with some electrical tape.
