1994 Intrepid 3.5 V6 Fuel Pressure Regulator FUEL LEAK!
doug2060
01-03-2008, 03:18 PM
Lately I have been smelling gas when I start my car. I looked everywhere but didn't find anything until today. I noticed gas around the rim of the fuel pressure regulator but it wasn't leaking as the engine was running and the car runs normally. I wiped it off while the engine was running and it wasn't leaking at all. Once it dried up I turned the car off. As soon as I started it again the gas re-appeared. It's not a major leak but any leak is a bad leak when it comes to gas. It's just enough to cover the rim of the regulator and some of the surrounding area but not enough to drip to the ground... Any advice is much appreciated...
wafrederick
01-03-2008, 07:10 PM
Could be the injector o rings or the rails.The rails are out of a plastic material and crack.Chrysler did have problems with both,the rails are not cheap and is a dealer part only,about $175.00 a piece.Try geting an used one from a junkyard that is still in good shape first.
doug2060
01-04-2008, 02:13 AM
I'll see if I can get one from the junk yard. It's the side with the regulator in it so I can just bypass all the troubleshooting by replacing it. I may go ahead and get an O ring kit for it while I'm out just to be sure...
