Yukon Climate Control - Cold Air in Cabin
6riley
01-03-2008, 11:40 AM
My 2001 Yukon XL has a significant cold air leak into the cabin, on the passenger side. Even while the heater is on full blast, the passenger side receives cold outside air to the point where someone can't sit in that seat, at least not during cold Minnesota winters. I can switch the control knob to "re-circulate air only" then the problem stops. But for some reason the "re-circulate feature" only stays on for 10 minutes then goes back to the "fresh air" position.
tazz1037
01-29-2008, 05:02 PM
I have had the same problem in the last 2 GM trucks (Tahoe and 2500HD). Here is how I found to fix the issue. This was posted in another forum somewhere. Hope this helps you!!!!
__________________________________________________ _____________
"I think theres a bulletin on this, You need to remove the black plasitic cowl by the wipers. on the right hand side you will see a small rectangular cover on the top of the firewall that looks like it has been painted over. cut around it with a razor blade and remove it. below the cover there should be a rectangular duct with a gap (maybe 1/2 in wide)between it and another duct piece. The gap will be about 1 1/2 in below the rectangular cover you removed youll need to seal up this gap, butyl tape or silicone work good. then reseal the cover with silicone and let dry, that should take care of the air leak"
MORE DETAILED
Passenger SIde of Vehicle Colder/Warmer Than Drivers SIde (Repair HVAC Case to Cowl Seal) #01-01-37-008 - (Mar 29, 2001)
</TABLE>Passenger Side of Vehicle Colder/Warmer Than Driver's Side (Repair HVAC Case to Cowl Seal)
1999-2001 Chevrolet and GMC C/K Pickup (Silverado, Sierra) and Utility (Suburban, Tahoe , Yukon , Yukon XL) Models
2002 Cadillac Escalade
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=791061&psdid=210&evc=sm#ss1-791061 (http://service.gm.com/servlets/BlobShtml?ShtmlFile=791061&psdid=210&evc=sm#ss1-791061)">Condition
Some customers may comment that the passenger side of the vehicle may be:
<LI class=MsoNormal style="COLOR: black"><LI type=1>Colder than the driver's side when the heat mode is on. <LI type=1>Warmer than the driver's side when the air conditioning (A/C) mode is on.
There may be dampness on the vehicle dash assembly when the A/C mode is on.<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=791061&psdid=210&evc=sm#ss2-791061 (http://service.gm.com/servlets/BlobShtml?ShtmlFile=791061&psdid=210&evc=sm#ss2-791061)">Cause
Condition may be due to poor sealing of the HVAC air inlet case to the front of dash or the recirculation mode door actuator may not hold the recirculation door closed while driving.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=791061&psdid=210&evc=sm#ss3-791061 (http://service.gm.com/servlets/BlobShtml?ShtmlFile=791061&psdid=210&evc=sm#ss3-791061)">Correction
Replace the recirculation door actuator (if necessary) and repair the HVAC case to cowl seal using the following procedures:
<LI class=MsoNormal style="COLOR: black"><LI type=1>Place the A/C control in the manual heat mode. <LI type=1>Remove the fixed mast radio antenna. <LI type=1>Open the hood and install fender covers. <LI type=1>Remove both wiper arm assemblies using the following procedure:
<LI type=A>Disconnect the washer solvent hose from the air inlet grille panel nozzle. <LI type=A>Remove the cover from the wiper arm retainer. Remove the retainer. Important: Use a battery terminal puller in order to remove the wiper arm.
Rock the wiper arm back and forth in order to loosen the arm from the drive shaft. Remove the wiper arm.<LI type=1>Lower the hood. <LI type=1>Remove the air inlet grille panel using the following procedure:
<LI class=MsoNormal style="COLOR: black"><LI type=A>On each end of the air inlet grille panel is a rubber flap for the hood hinge cutout. Lift this flap and remove the air inlet grille panel attaching screw. <LI type=A>Remove the air inlet grille panel center top push pin. <LI type=A>Remove the clips that position the forward edge of the grille panel to the top of the cowl. <LI type=A>Disconnect the windshield washer supply hose from the bottom of the grille panel.
Remove the air inlet grille panel by sliding the panel rearward up the windshield and out.<LI type=1>Just to the left of the right hood hinge, on the horizontal surface of the cowl, locate a cover that is sealed in place. The cover has TRW stamped into it. <LI type=1>With a sharp knife, cut out the panel following the panel impression in the sealer tape. <LI type=1>Place a lifting device between the cover and the dash. Lift the cover enough to allow another tool to depress and release the front retaining tabs by pushing rearward on them. Remove the cover. <LI type=1>Look through the opening where you just removed the cover. You will see what looks like a piece of foam about 76 x 127 mm (3 x 5 in). This is the A/C recirculation door that is within the HVAC module. <LI type=1>Reach into the opening and carefully pull on the air inlet recirculation door. If the recirculation door moves with very little effort, replace the air inlet (recirculation) door actuator (Manual systems only). For systems with the Automatic Temperature control, initialize the system using published Service procedures. <LI type=1>Between the top of the HVAC air inlet module (appears as a 6 mm (1/4 inch) black strip) and the cowl sheet metal is a foam seal. This foam seal may be improperly positioned or damaged in some way (insufficient crush/sealing). This may allow outside ambient air to enter the passenger compartment incorrectly (under driving conditions). This can be corrected using the following procedure:
<LI class=MsoNormal style="COLOR: black">Important: It is imperative that a good seal be achieved over the entire surface areas (no voids or skips), especially around the rear and sides of the HVAC case to cowl areas.
<LI type=A>Seal the area between the cowl and HVAC case with RTV Silicone Rubber Sealant, P/N 12345739 (in Canada, use P/N 10953541). <LI type=A>Using your finger, from the engine side of the cowl, ensure that the foam is stuck nicely to the HVAC module and does not have any distortions. <LI type=A>From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, place a shop cloth into the opening and cover the blower fan. This keeps silicone from dripping onto the motor and causing an imbalance condition. <LI type=A>From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, apply the RTV silicone to bridge the gap and cover the foam between the cowl sheet metal and the HVAC module case. Inspect your work with a light and a mirror. Ensure that no gaps or skips are present in the RTV seal.
Inspect your work for potential drips, runs, etc. If no problem is seen, remove the shop cloth covering the blower motor.<LI type=1>Apply a 3 mm (1/8 in) bead of weatherstrip adhesive, P/N 12345097 (in Canada, use P/N 10953479) around the opening in the horizontal surface of the cowl, where the cover fits into the cowl. <LI type=1>Place the cover on the workbench, top on the surface, and apply a 3 mm (1/8 in) bead of weatherstrip adhesive on the edge of the cover. <LI type=1>Place the cover into the cowl opening and snap into place. <LI type=1>Apply another bead of weatherstrip adhesive around the joint between the cover and the top of the cowl. Smooth this bead into a smooth surface with a finger or tool of some kind. <LI type=1>Place the leaf screen to the cowl. Attach the washer supply hose to the bottom of the air inlet grille panel. Do not place the fasteners in at this time. <LI type=1>Install the radio fixed mast antenna. Tighten 1/4 turn after contact is made with the base. <LI type=1>Lower but do not close the hood. <LI type=1>Center the opening in the air inlet grille panel around the antenna mast and then install the air inlet grille panel retaining screws.
Tighten
Tighten the screws to 2 N·m (18 lb in).
<LI type=1>Raise the hood. <LI type=1>Reinstall the air inlet grille panel center retainer and front edge retaining clips. <LI type=1>Cycle the wipers to ensure the wiper system is in the parked position. Important: Inspect the windshield lower edge on each side. About 51-76 mm (2-3 in) from the bottom, you will find a 13 mm (1/2 in) long black mark embedded in the glass. The black line is the position for the wiper blade to be in when the wiper system is in the parked position.
<LI type=1>Install the wiper arm assemblies. Position the wiper blades just below the black marks in the windshield. <LI type=1>Install the retaining nuts.
Tighten
Tighten the retainers to 25 N·m (18 lb ft).
<LI type=1>Reconnect the washer hoses. <LI type=1>Remove the fender covers.
Close the hood.
MORE DETAILED
Tighten
Tighten
Close the hood.
Homerzip
12-07-2008, 01:49 PM
I found this post very helpful....Thanks TAZZ1037
stratmax
03-05-2010, 09:27 PM
I have an '09 Yukon Denali, bought it November '09 the problem occurred in December when it started getting cold out. My wife complained that her side of the vehicle had cold air coming from under the dash, and no heat coming out of the vents on her side.
Took it in to the dealership, well what do they do, take it back in the garage and look at things return the vehicle saying nothing is wrong.
Returned next week, same problem they replaced a servo motor, now getting heat out the side vents, but still have cold air coming under dash. NOTE: glove box is ice cold.
Returned to dealer took technician for test ride, at 60mpg he too noted cold air, found service bulletin put silicon around seam in heater box.
Well this didn't solve the problem, returned vehicle back to dealership, here again their idea was to take the vehicle back in the garage "found nothing wrong" I should note that the outside temp was about 42. I was irked, but took the Yukon for a test drive, everything was fine. So on drive home I have to cross a significant mountain. Once temp got below 40 I had cold air coming back into the cab on the passenger side. Now I'm getting real irritated.
The dealership doesn't believe me, so I waited until the temp outside was cold, returned and take the assistant service manager, he notes the cold air coming in. Their idea for the fix, pack insulation around the heater box. Didn't work.
On a recent trip to Chicago, temperatures in front of my wifes legs got down to the low 40's. Back to the dealership and a meeting with a regional technical specialist....
Well GMC has finally agreed to Lemon the Yukon, now waiting for the paperwork to be processed.
