93 T/A leaking extreme amounts of oil please help!!!!!
Rahatee
12-31-2007, 08:57 PM
my 93 t/a is leaking extreme amounts of oil i have to put oil in it like every week it leaks real bad when i first start it after its set for awhile and i changed the oil filter but still cant find the problem i once looked under the car and saw the oil filter was covered in oil which led me to change the filter but its still leaking the oil puddles are always on the passenger side if anyone knows where its leaking please let me know so i can remedy this
and by the way im running 10w-40 oil in it
stepho
12-31-2007, 11:40 PM
The old gasket isn't stuck to the block is it? Sometimes that happens the old gasket gets hot and sticks to the metal then when you put the new filter on it wont seal right because there is two gaskets.
Rahatee
01-01-2008, 04:56 AM
i prob should have mentioned that the first time but no there is no other gasket stuck to the block i checked when i installed the new one also the gasket around the oil pan has been changed b4 and is pretruding abit which is leaking small amounts of oil but not enough to be causing this prob thanks for the reply
waterskier_69
01-02-2008, 12:07 PM
There is dye you can put in the oil that shows up under a black light. If you do this and look for the leak before too much more oil comes out then maybe you can find it. Good luck.
Rahatee
01-03-2008, 08:00 PM
thanks for the reply i read some things on the internet and people mentioned that they had an oil leak similar to mine and it was the oil cooler line so im going to check that tomorrow hopefully that is the problem but if any one else has any suggestions please list them i need all the help i can get on this one lol
philly rs
01-04-2008, 09:00 PM
is that a lt1? or v6? if its a lt1...maaaaaan. my maro is a lt1 and i just got it to stop leaking...for now..the lt1 leak is a common thing. they are old as hell and to be real all the gaskets need to be changed at this point.i pulled my motr and changed the oil pan one, rear main seal, which were the 2 i had thought it was, and a buch of others i just came by...so far so good no more leak...its alot of work but thats the only way to get it to stop
Rahatee
01-06-2008, 04:11 AM
To reply and close this thread i finally figured it out and might be something you want to check on your camaro is the base that the oil filter screws into after you get the filter off in the middle of the base is a 13 mm bolt make sure it is tight if not it will leak oil at the top where it connects to the engine hopefully if anyone else has this prob it will help thanks for the replies everyone
