help my baby is down!!!!!!!!!!
91mitsubishi3000gt
12-30-2007, 02:19 PM
I have a 91 3k SL. last sunday i was driveing her,she was doing fine i came home then i was going to a christmas party and when i got out of the driveway she just died on me. i pushed it back to the car-port and I noticed the '' engine'' fuse was popped. I replaced the fuse and when I turn the key to on the fuse popped again I know its a short but where would it be comming from?
blu3kgt
12-31-2007, 01:43 PM
did the fuse pop again as the car was trying to turn the engine over, or just when you turn the key to on but engine off??
91mitsubishi3000gt
01-01-2008, 12:56 PM
it popped when i turned the key to on and engine not started (off)
liquidPunk
01-01-2008, 02:04 PM
Have you done (or had done) any work recently? Have you done anything inside the steering collum? or maybye put in a new radio
If you havent done anything then it will be difficult to find the short, it shorts when you put it into acc not actually trying to crank the engine right?
91mitsubishi3000gt
01-02-2008, 06:31 PM
I put a new radio in but that was like over 5 months ago way way before this problem, other than that no work was done on it recently
right on acc
oempartssupply
01-02-2008, 08:48 PM
You may want to check behind the wireing for the radio anyhow. I hade one about a year ago that the wires had slipped out of the back and started touching and I had to replace the fuse.
liquidPunk
01-03-2008, 06:50 AM
EXACTLY! Take out the radio and thoroughly check all of the connections there, even if they look good, make sure that no wires are poking out, most liley though this isnt the problem because most of those wires would blow a different fuse.
after that, take apart the steering column (alright, how the hell do you spell that? it's driving me crazy and im at work without a dictionary! ugh).
there are four (i think) screws recessed into holes, takt them out and then pull the top and bottom halves apart. now you need to check all of the wiring in there, starting with those that are connected to the ignition. look carefully and make sure the wires are out of the way when you put it back together. if not there then look up underneath the dash, if not there then it may be time to head to the electrical shop. (or just bug stealthee for an answer
oempartssupply
01-03-2008, 10:19 AM
You are right. And it is column....www.dictionary.com.... my lifesaver many times. It could be the ignition switch are any number of wires there. You may also want to remove the lower dash piece under the steering column. Just pop out the rear wiper switch and the mirror dimmer switch and catch the two 10mm bolts there and then the two on the bottom pretty much exactly below them and drop it out of the way so you can see all of the wires. If you find something that you think needs replaced give me a hollar at I have a parts car out here. I got an ingnition switch and everthing.But if no luck there do what we all do ask Stealthee...lol
liquidPunk
01-03-2008, 01:07 PM
Muahaha its so true though.:grinyes:
thanks that word was bugging the hell out of me!
anyway if you have a parts car, I am looking for the reverse bulbs wiring harness. for some reason they were cut out of my car before i got it.
oempartssupply
01-03-2008, 06:49 PM
Sure no problem. I could send you both harnesses with the bulbs for 30.00 including shipping. Just let me know.
Stealthee
01-03-2008, 10:32 PM
Wait, how the hell does my name keep coming up when I am not around? :lol:
oempartssupply
01-04-2008, 11:05 AM
Hey remember you are not anyone you are "the Stealthee"...lol
91mitsubishi3000gt
01-04-2008, 08:50 PM
i took it to a shop and they could not find out why it keeps blowing.the bill got too high so I had them stop working on it. im donating the car. i would sell i but it does not pass smog it burns (not leaks) oil, and its not running. it will be very hard to sell for what it is worth. at least this way ill get a tax wright off for 2007. I say good bye to her tomarrow
oempartssupply
01-04-2008, 10:27 PM
You can donate it to me if you want...I am a lost cause...lol.
