95 deville wont start.. security light
edk172
12-29-2007, 04:12 PM
good battery, goodlights, wont turn over at all. The security light comes on and then the 3 minute count down begins after keys are removed from ignition and it still wont start. any help would be appreciated. thank you.
caddydaddy
12-30-2007, 05:47 PM
Could be an ignition cylinder problem. You really need to get a service manual to diagnose the problem.
edk172
01-05-2008, 10:44 AM
Owners man. said to clean keys and check fuse. Checked,good. checked ohmes on key chip,1128,1133 ohms. Followed wires down column.,checked at pannel,same reading when key in off pos. on pos. no reading. Two seperate keys
edk172
01-06-2008, 04:11 PM
I recieved a tip from a friend who referred me to this site. My vehicle anti theft system (VATS) may be the problem. I googled vats bypass. It referred me to VATS.likeabigdog.com . The car started rite up. Maybe this will help someone else. This is a good site, thanks for the help.
caddydaddy
01-06-2008, 06:58 PM
Thanks for the tip! So you just bypassed the VATS and it runs fine?
edk172
01-08-2008, 07:42 PM
That's correct. I got lucky. I got positive results from the first step in the VATS bypass. If needed there is a next step. Read about it at VATS.likeabigdog.com
