98 eclipse clicking noise from rear driver side
stillstanding
12-29-2007, 03:28 PM
clicking noise in rear driver side tire when driving but stops when i turn the wheel left or hit brakes gets louder when turn wheel right! please some one help me out!
SilvrEclipse
12-29-2007, 03:53 PM
Welcome to AF
I can barelly read your somewhat of a paragragh, much less try and help you solve the problem. You need to include what model you have, AWD?
From what I can tell there is a clicking noise coming from the rear drivers side tire. It stops when you hit the brakes or turn left but gets louder when you turn right?
Check your brake pads and also check the wheel bearing. Jack the car up and see if you can shake the tire at all.
JoeShmoe
12-30-2007, 09:56 PM
Wheel bearing, or the cotter pin being loose. How long has the noise been there and did you do anything to the wheel before the noise started?
