radio code??
level1stealth
12-29-2007, 09:06 AM
i have a 04 acura mdx..the battery was unplug then plug again and now the radio doesnt work anymore..it needs the "radio code" whice i dont know.anybody out there knows the radio code???
somick
01-03-2008, 04:40 PM
If you prove to the dealer that you are the owner they should give you the code. That is the only way I know.
Sam
mollea
01-28-2008, 09:46 AM
After some time on the phone with the dealer, my 2003 honda has a sticker with the 5 digit code in the car. Mine happens to be on the glove box - if I open the glove box, it is on the outside of left side. It first lists the 5 digit code and then the serial # which is about 8 digits.
viper357
02-09-2008, 04:06 AM
need code for my raido i have a 2003 honda cr-v the ser number 17053820 and the ref- cqeh826lc
somick
02-11-2008, 11:15 AM
I have heard that manufacturer sometimes places stickers with codes inside the glove box. Look there first. If it is not there look at the post #2.
Good luck,
Sam
superbeemdx
01-06-2009, 04:32 PM
i also have that problem, i just bought my mdx and i dont have the radio code for it, does anyone know how to retreive it? :naughty:
somick
01-08-2009, 11:09 AM
i also have that problem, i just bought my mdx and i dont have the radio code for it, does anyone know how to retreive it? :naughty: I hope you tried recommendations mentioned in the posts #2 and #6.
I have copied the following from one of the forums:
This may not work with all radios but does for my 2004 Honda Odyssey with
RES. To find the serial number without removing the stereo. Turn on the key,
make sure the radio is off. Hold down the #1 and #6 preset buttons and turn
on the radio. It will then show the radio's serial number on the display.
This only works if the radio is locked out, you cannot find the serial
number that way if the radio is working properly.
I hope this helps,
Sam
