RUning fan blow up fuse
fastcivic90
12-27-2007, 02:54 PM
i have a 97 accord that is blowing fuse's... and the parking lights dont want to turn on and i need them to drive the car speacially at night .... at first they turned on... the fan is running good.. but as soon as i turn the lights on the fuse messes up we changed them twice now the light dont even turn on.. n as always the fan works good
jeffcoslacker
12-27-2007, 03:05 PM
What fan, the radiator fan or the blower for the heat/A/C?
fastcivic90
12-27-2007, 03:35 PM
The radiator fan every time I turn on the ligths the fuse blow
jeffcoslacker
12-27-2007, 03:59 PM
Don't know about your year, but on the older ones these two systems shared a wiring harness that ran over the top of the radiator core support. Make sure you don't have some wiring narfed up or pinched in that area if they appear to split from the same harness...
If your parking lights are like my '95, you have to turn the switch all the way to headlights and then back to the parking light position for them to come on...
Now is your fan running continuously? It shouldn't be, unless you are running A/C, then both should run. If one is running all the time, the relay is stuck or the wiring is shorted to another system's wiring and is stealing power from it...
If that's the case, try moving the wiring around and see if you get a reaction from it (like the fan stops or you hear/see arcing)...
jeffcoslacker
12-27-2007, 04:00 PM
I was just thinking...you mean you have no parking lights even with the headlights on?
