98 T&C van transmission
MT-2500
12-27-2007, 01:18 PM
98 T&C van 3800 engine 604E transmission.
Does anyone have the cry part no for for the new oem od planetary gear kit with everything in one kit?
Cry dealer got a bulletin on it but he can not find it for part no.
Thanks for any info on it MT
wafrederick
12-27-2007, 04:59 PM
I don't and I know another option.Weld the end of the pin through the diff housing on the outside where it sticks out and do it to both sides.You can get it aftermarket from a transmission parts place.Check the cooler too,it might be bad and will cause this.
MT-2500
12-27-2007, 05:57 PM
Thanks for the info.
Getting the new OEM updated OD planatary gear set is my main problem.
Dealer does not have part no.
And 10-4 on flush the cooler.
It has a new rad but will flush and check.
Come to think about it the transmission went out about a mo. after rad replaced.
It shelled planatary gears all out.
And one set of clutches.
2001 up have the spider gear pin lock tab set for them.
v8carreragts
12-27-2007, 07:22 PM
You can get the planitary set here:
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=2&Product_Code=A92583B
They guarentee that this is OEM. The dealer quoted me almost double the price.
I would also suggest the differential pinion shaft retainers ($11) and a TransGo shift kit. ($22) This kit does not do whar conventional shift kits do. It fixes what causes bump shift and a few things that cause limp mode.
MT-2500
12-28-2007, 08:51 AM
v8carreragts
Looks like a good place to get transmission parts.
And 10-4 on the pinion shaft retainers.
Thanks
MT
Thanks
MT
