Tach install (read first)
Touge180
02-17-2003, 12:31 PM
alright i went to install my tach and i unscrewed the four screws from under the dash to get behind the Gauge cluster but i can't get it off to hook up help.
gunnmen01
02-17-2003, 04:44 PM
Did you pop off the 2 small covers and take out 2 screws from the back side of the cluster???
gunnmen01
gunnmen01
Touge180
02-17-2003, 10:07 PM
what two small cluster all i did was take out the screws from the dash and then tried to take off the cluster but couldn't is the a diagram or something cause im stuck i want the bastard in now or i'll :cry:
antiguabill
02-18-2003, 04:20 AM
if you didnt spot the two screws in the front, then look through the windscreen from outside...
if you did, then your problem may have been having to disconnect the wiring from the switches. just sqeeze and they should pull out.
if not then i dunno whast up.
׿Pyro¿×
02-19-2003, 12:17 AM
I know there is 4 screws as in the 2 on the bottom then the 2 on the top of the cluster in the back. But I can't get one out. I think it's really really on there. Any suggestions on how to take out a screw that won't budge?
Jameson
Jameson
antiguabill
02-19-2003, 02:11 AM
wd40. gt85. a big 'ard bastard that goes to the gym. one of them torque wrench type things with a screw head attatchment and long handle.
