I WANT a Resin mold of my CAR!!!!
Mean_B16
02-16-2003, 10:34 PM
I have seen plenty of these resin molded Nascar bodys in model shops and it gets me thinking. Does anybody know how this is done?? Is it something I can do in my home or does it take expenseive machines to make them?? I would love to mold copies of my models after I put a kit on it, then i could save SO much time in making certain kits. Does anybody know how to make the Resin body molds??????????
endlesskev86
02-17-2003, 12:56 AM
i think you should try askin FOTW
erictk
02-17-2003, 03:14 AM
Here's a link that Jay posted that I found while searching for resin casting. Hope it helps.
http://www.mgussin.freeuk.com/1-32Casting.htm
Ragnarok043
02-17-2003, 03:28 AM
yes you can make resin copies yourself, but casting an entire kit can get labor intensive especially if you have do alot of 2 part molds. it can be a little expensive starting out but it wont cost you an arm and leg though. heres list of what you need
Polyurethane Resin
RTV Silicone - go with Platinum Cure(1:1), easier to mix. you dont need the strength of a Tin Cure(1:10)
Styrene Sheets - used to build mold box
Klean Klay - for 2 part molds, used to fill voids. its a synthetic clay that wont inhibit the curing of the RTV Silicone.
Mold Release - not really necessary but makes removing castings easier and increases the life of the mold
i think thats pretty much all the essential items you need. heres an article on resin casting
http://www.childofmecha.com/Modeling/Resin/Resin.htm
also on a side note, dont mix the Polyurethane with a wooden stick, the stick have enough moisture to cause the the resin mixture to bubble.
Polyurethane Resin
