How to tell if I have keyless entry 2002 Blazer LS
sadlerb_98
02-16-2003, 01:16 PM
Hello,
Nice forum here. I have a 2002 Chevy Blazer LS that I bought yesterday. The dealership didn't have any key fobs for it. How can I tell if this car has keyless entry? Is there some sort of test I can perform?
Thanks,
SadlerB
Thanks,
SadlerB
Shortbus
02-16-2003, 01:25 PM
You can post or email me your vin number and I can check it out at work tomarrow.
Welcome to AF.:)
John
Welcome to AF.:)
John
sadlerb_98
02-16-2003, 03:50 PM
Thanks John,
Here is the VIN: 1GNDT13W12K178187.
I am glad I found this forum. Thanks for the help.
Bobby
Bobby
Shortbus
02-17-2003, 08:52 AM
Yours does not have factory keyless entry:( option AUO
You can still buy a GM accessory kit though, they look and function just like the factory installed units.
sadlerb_98
02-17-2003, 09:42 AM
Thanks for checking John. Is this something that I can install or should I take it to the dealer? Also, on another note. How can I get the radio code?
Thanks again,
Bobby
Thanks again,
Bobby
bowtiebandit
02-17-2003, 10:32 AM
You can actually just purchase the RKE module, goes right beside the parking brake on the lower hush panel. All the wiring is allready there, but the dealer will have to reprogram the BCM to activate the option. I've done probably 20 of these when our truck department made a mistake. Radio code is also a dealer deal, they have to pull the code out and make a phone call unless they left the plastic sticker on the radio itself. That had the code on it.
sadlerb_98
02-17-2003, 02:05 PM
Thanks! It sounds like I can just plug this into the wiring harness in the hush panel. Are there any online places that you know of that I can buy this from?
Thanks,
Bobby
Thanks,
Bobby
bowtiebandit
02-17-2003, 02:07 PM
John maybe able to help you with that..I am sure it's dealer item only.
sadlerb_98
02-17-2003, 02:27 PM
Sure thing. Is that hush panel the one right above the parking brake? I think it has four or five hex screws holding it on. I pulled it down just now and it has a ton or wires there. Is that where that RKE module will go?
Thanks again for the info.
Bobby
Bobby
bowtiebandit
02-17-2003, 03:10 PM
This is left side of dash..arrow points towards front of vehicle
sadlerb_98
02-17-2003, 03:16 PM
Thanks bowtiebandit,
I think I am in the right spot. I assume that #1 is pointing to the RKE module location?
You guys are great! I never thought that I would get this much help.
thanks,
bobby
thanks,
bobby
Shortbus
02-17-2003, 03:18 PM
Bobby
Here is the best view I have..
Edit : LOL bowtie beat me to it :D:D:D:D:D
To buy it check out www.google.com and do a search for gm parts.
Or just check my profile home page out.
I don't like to use this forum to advertise my web address for parts.
Here is the part number. 15042969 RKE Reciever.
:Dhttp://files.automotiveforums.com/uploads/495924module.jpg
Bobby
sadlerb_98
Also,
This is the closest thing online I can find to the RKE.
http://www.aatechnologies.com/../gmalarms/vke1000.asp
Do you think this is the OEM one or a copy?
Thanks,
Bobby
Thanks,
Bobby
Shortbus
02-17-2003, 03:29 PM
It is OEM and at a great price to only 9 dollars above GM cost on them. They probably bought into a large quanity like we do.
sadlerb_98
02-17-2003, 03:40 PM
Cool:D :D
I will go ahead and order that in a few days. I will stop by the dealer and get them to reprogram the BCM. I will let you guys know how it goes.
Thanks again,
bobby
Thanks again,
bobby
sadlerb_98
02-17-2003, 03:55 PM
I just pulled down the cover again and saw the plug-in. What is the going rate for the reprogramming? Just so I will know how much I need to set aside for it.
thanks a million
bobby
thanks a million
bobby
bowtiebandit
02-17-2003, 03:57 PM
around here somewhere around 35 bucks.
sadlerb_98
02-17-2003, 03:59 PM
awesome. That is not too bad.
thanks,
bobby
thanks,
bobby
Shortbus
02-17-2003, 04:10 PM
Is that for .5?
Is that for .5?
bowtiebandit
02-17-2003, 04:20 PM
We charge .5 but you know I don't even know our labor rate :(
Shortbus
02-17-2003, 04:25 PM
LOL I did'nt know ours either but had to ask, we get 90.00 an hour, but thats Scottsdale AZ for you.
zetapsi538
04-03-2005, 02:28 PM
My problem is so close to this I had to post here. My wifes 2002 Blazer came with Keyless entry code AUO or whatever, but it has an aftermarket keyless entry module installed in it as well, the OEM one has been removed. After I put in a GM moudle and pull this aftermarket one what needs to be done?
KindOfBlue
05-03-2005, 01:46 PM
That link is now dead, but I've found the VKE 1000 at www.oem-auto-accessory.com (http://www.oem-auto-accessory.com/vke1000.html) for $145. Is that a reasonable price?
tazl3oy
03-09-2007, 11:30 PM
can someone help me i have a 03 blazer and i dont know if it has keyless can someone help me out thanks alot... vin # is 1gndt13x63k134549
maxwedge
03-10-2007, 09:56 AM
Welcome to AF. LS, this was not factory std. You should have posted this Blazer forum. Check with a Chevy dealer for the rpo code and check the codes in the glove box. Also this thread was 2 years old, start a new one on the future
step1984
10-13-2008, 07:21 PM
I'm looking to buy new keyless remotes for my 2002 Chevy Blazer. The remote I have stopped working and I changed the battery so that's not the problem. I am looking on ebay and finding some with the same numbers on the back of the remote, so those should work also. But there are others out there that say they work for the 2002 chevy blazer and the numbers are different. 2 question.
1) Will different remote numbers work on as well? (Same look, just different GM/LEAR, FCC ID, and CANADA numbers)?
2) If I bought 2 remotes, (one with numbers that match the current remote, and one with numbers that are different) will both remotes work if programed?
jlpyles
01-25-2013, 12:34 PM
hello,
john
is there anyway you can help me figure out which remote i will need for my 01 blazer ls.
vin # 1GNDT13W212146430
looked under dash and there is a black box.
FCC# KOBUT1XR
15732806 is also on it.
john
FCC# KOBUT1XR
