Jetta VR6 OBD II code
Sammysj
02-13-2003, 12:45 PM
Does anyone know what componant 22, in the OBDII code P0322 represents, I am at wits end trying to figure how to fix this problem.
Deakins
02-13-2003, 12:52 PM
'No Signal'
Sammysj
02-13-2003, 03:13 PM
Signal to WHAT or from WHAT????, I know what the code means but what component failure would cause a no signal condition.
Deakins
02-13-2003, 03:53 PM
The engine speed sensor.
Sammysj
02-13-2003, 04:21 PM
Would the engine speed sensor cause a no start condition?? Let me give you a little history. About three months ago the check engine light came on. Drove fine, no problems. Check engine light went off in a couple days. A month a go it came on again. Still no problems ran fine. A week ago I went to start it(check engine light still on from a month ago.)And it turned over great but did not start. Waited a few minutes, and then it started. This has happened twice now. But haven't had a problem with it since. Check engine light is still on, got the codes P0322, and P0411.
You have been the best help so far. I appreciate any input. Thanks!!
Joel
Deakins
02-14-2003, 12:23 PM
Emmm...
Have you checked all fuses? the o2 sensor?
Do you have a vaccum leak?
Do you by any chance have access to a (newer) VAG-COM?
