Clutch problem
civicgee
01-29-2003, 11:53 AM
My '93 Civic need's help , clutch pedal stays down will not lift anf if it does it feels like I hardly have a clutch. ,,, If anyone has any idea what the problem my be please let me know. Feering for the worst (new clutch)
Thanks
Thanks
jaxle
01-29-2003, 02:48 PM
did u check your clutch fluid?
CivicSpoon
01-29-2003, 03:02 PM
If your fluid seems like there is anough in there, try pumping it (pull it up with your hand if you have to) and then get someone to push it down while you bleed it.
Emilio
01-31-2003, 10:12 AM
Nah i don't think your clutch disk itself is gone. SInce you have almost no feel in the pedal, since its a hydraulic system u got a leak somewhere. If you are low on fluid put some in and see if the pressure remains. If it doesn't you have one of 4 problems:
1. Your master cylinder is gone (the one right behind your pedal)
2. Somewhere along the lines there's a leak.
3. Your slave cylinder is gone (check it out its sticking from the front side of the tranny, its surrounded by rubber that you have to remove)
4. 2 or all of the above
