How many cans of paint do you use on each model body?
integra818
01-27-2003, 01:43 AM
tazdev
01-27-2003, 01:47 AM
Just on the body, 1 can.
On the calsonic GT-R I used 1 1/4 for the whole car inside and out
integra818
01-27-2003, 01:54 AM
I'm building the same kit exept different decals, rims, and the body is molded in green. It's the castrol Rb skyline gt-r (R-32).
I use 2 cans of spray paint on each car, is this too much?
tazdev
01-27-2003, 01:59 AM
not necessicarily. Each model is different as to the amount it takes. It depends on the colour also
Jonno
01-27-2003, 02:03 AM
My R34 V-spec II has already taken one can, and I need to buy another because of a few pieces of dust in the paint work. It also depends on what type of paint, IMO there isn't enough in the Tamiya cans but when I use other paint, 1 can can last me up to 3 models.
bibendumz
01-27-2003, 02:23 AM
on the average is 1/2 can for 1 car....my record is 4 cars per can...
Focus2000
01-27-2003, 03:18 AM
I started off at about 1 can per car, but I'm now down to about 1/2 a can. Since I started warming the cans before spraying I find the paint flows better and so I use less to get a good finish. Thanks to P-Man for that tip ;)
kicker1_solo
01-27-2003, 03:20 AM
primera man
01-27-2003, 05:40 AM
All going well, i can get around 3 maybe 4 cars to a tin
Fooesboy
01-27-2003, 07:40 AM
That's sick!
If I'm lucky I use 2 cans per car, my F-40 is on it's 3rd can and counting!
Vric
01-27-2003, 07:59 AM
usualy, I make 2 kit with one can !
COZMO6476
01-27-2003, 08:01 AM
im at the stage where i use 1 can of primer for 2-3 cars and about 3/4 of a can per car which makes the can practically useless. slowly i will work my way towards the magical number of 3 per can... that would save me loads on cash... someday.
Midnight Racer
01-27-2003, 08:15 AM
I usually use 1/2 can for 1 car.
fwdfreak
01-27-2003, 09:57 AM
i use 1/20 of a can with an airbrush :D
freakray
01-27-2003, 01:25 PM
That sounds like a bit too much paint.....how much detail are you trying to cover?
I am about the same with my paint cans, but I keep that 1/4 can because you can still use it to spray small parts and the like that aren't going to require a lot of paint.
Ray
Street Sweeper
01-27-2003, 03:20 PM
I get 1 car out of one can of paint and the same for primer.
God|Zilla168
01-27-2003, 10:02 PM
I can get 2 cars per can, but that is for the special color. But basic color I use my airbrush and depending on the car and paint I can generally get 4 cars out of the little bottle. Primer I use the automotive stuff and that last about 8-10 cars.
64 Chevy
01-27-2003, 10:31 PM
it depends on what kind of spray can, one for a small testors can but i can get a few out of a larger krylon can
01-27-2003, 10:38 PM
Originally posted by Vric
usualy, I make 2 kit with one can ! Ditto!
impreza2k2
01-28-2003, 12:12 AM
hey, which one are u using? i always want to get the automotive one since they are large and cheap:p but i dunno which one is good.
Usually 2 cars a can of tamiya spray paint and i sometimes i try to make it 3 cars:D they are just too expensive 12cad each:( i've spent over 100 bucks so far just for the spray paint.:rolleyes:
Fooesboy
01-28-2003, 07:36 AM
I'm wet sanding in between every second coat, I had it "finished" and clear coated but polished through near the wheel arches, I have repainted it, but got some dust in it .......... sort of lost intrest at the moment, but will start again soon. This car has been a mamoth project, but I want it as perfect as I can get it. The detail is still there, but it won't take much more paint!
acunda
01-28-2003, 12:08 PM
usually one can per car is enough, but for some projects i need another half to finish it. :)
freakray
01-28-2003, 12:32 PM
You can strip the paint off using regular brake fluid.....then you could start from scratch....and not lose the detail....
Ray
