worse luck ever
emerge
01-23-2003, 08:38 PM
if any of you think you have it bad sometimes with mods on your car, listen to this fiasco with my headlights...
1. ordered halo projectors
2. 1week wait for delivery
3. one headlight is defective and high beams don't work
4. company sends replacement headlight
5. 1week wait for delivery
6. ran out of quick splicers (to wire halo)
7. attempted to splice wires myself
8. touched two exposed wires (pos and neg), blew fuse and headlight switch
9. 160$ for new headlight switch + installation
10. wired halo into fuse (finally, it works)
11. wire gets disconnected
12. attempting to fuse again does not work
13. splice wire into other headlight wire
14. halo works (finally, again)
15. left halo not as bright as right halo
so just remember that when you get mad about something. i am redoing the entire wiring of the driver side halo tomorrow. hopefully that will end all this mess. peace.....
shepworldwide
01-24-2003, 10:24 AM
this is why you remove fuse and dis-connect battery before doing ANY electrial work on your car..n00b's take note
sorry to hear about your mishap
KrNxRaCer00
01-24-2003, 11:42 AM
sorry to hear about that. good luck tonite getting it working better. jus learn from ur mistakes for the future.
Self
01-24-2003, 09:19 PM
Just curious as to rather or not you got things back in working order? Hope so! Bad situation!
emerge
01-27-2003, 12:09 AM
ok everything is great now. as you can see from my sig, i got the lights working. i agree with you shep, it was stupid of me to work with the power on. i learned to take things slow and do it right the first time. i spliced the driver side earlier today and tested them out this evening. they work great. finally, i can go back to looking into other mods... i might be able to post more pics of the lights tomorrow...peace
shepworldwide
01-27-2003, 06:09 AM
how is your vision at night? and what size bulb are you using?
kicker1_solo
01-27-2003, 06:32 AM
Originally posted by emerge
peace peace :wave:
:D
peace peace :wave:
:D
sikkcivic18
03-20-2004, 12:34 AM
i just put in my halos and i have the same problem you had with the passenger side being dimmer than the other. when i installed them i unplugged the battery and then wired everything right. and when i turned on my car the engine started putting. what should i do? any advice on what is wrong?
