Old 01-20-2003, 09:10 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Starting problems.
Okay, I have a question. My car will not start.
Anyways, here are the symtoms. Put the key in, turn the ignition, and click. Try again, click. Again, click. Nothing. Now, I know it is not the starter. I pulled the starter, opened it up, and the brushes were a little worn, nothing big. Put it all back together, and hooked it up to the battery, It wizzes fine, and puts out about 100 amps. I even took it to the parts store, and they said it was fine. So, could it be the main relay? Or does the main relay only really cause problems with the fuel?
Old 01-20-2003, 09:40 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
man i have been having that problem for so long and i have so much money invested into why it keeps doing it. well it could be your ignition switch, is your ecu throwing any codes? whenever my car wouldn't start like that, it would just click, i would disconnect the battery for about 5 to 10 min and the bitch would start right up like nothing happened. but i still havn't figured out what the hell it is, it doesn'tdo it as much anymore but it still will do it now and then. if you figure out what it is let me know please
Old 01-21-2003, 05:28 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
is the connection good on the little female connector on the starter?>??
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 01-21-2003, 08:44 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
change the plug and HT leads as well (better to be safe than sorry for the price of them)
cheerz
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 01-21-2003, 08:52 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
yeah...main relay only deals with the fuel (I believe)... are all your engine grounds connected?? I ALWAYS had a problem with not connecting them all how bout the wires going to the starter? everything intact?
SOLD!
Old 01-21-2003, 09:00 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
It sounds like the starter selenoid...but maybe not if the starter is spinning off the battery.
Do you have another one you could try? - If you get one from a parts store, make sure you can return it if that isn't the problem..sometimes they are a little freaky on electrical parts like that.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-21-2003, 01:49 PM
kris's Avatar
Fixed it today. Kind of sucks working under a flood light.
Anyways, the problem was the little black wire, witht he female end on it. About 4" up the wire, it had a small slice in it, which was shorting out.
Thanks for the replies.
Old 01-21-2003, 02:59 PM
H4Bangin's Avatar
:smoka: same shit happened to my friends hatch
